fefepeto_kb
Dedicated UI for LabVIEW connector pane
Status: New
The connector pane is a very useful feature for defining what the parameters for the VI are, therefore how it interacts with its environment.
On the other hand, the development experience did not age well. The 32x32 icon that is divided into smaller areas based on the pattern selected for the VI feel small on today's screens. On top of that most of the functionality is hidden behind the context menu.
This feels like a lacking experience for a crucial feature, but we grow accustomed to it, there we do not complain. But that doesn't mean things cannot be improved.
I would personally prefer a new window being opened when I want to edit the connector pane. The pane itself could be represented with 5x magnification (or even better, user selectable): 160x160 pixels.
On the pane, we could have a dedicated drop down that facilitates the selection of the pattern.
On each connector we could have a border representing its current state: Dynamic dispatch/Required/Recommended/Optional.
Cycling trough these states would be available on left click, for example, and reversing the direction with a shortcut, like ALT + left click.
Connecting the front panel terminals to the connector pane could be done by dragging and dropping to the desired place. To make sure that mistakes do not happen, the drag operations shall not move the front panel controls on the panel itself.
To make the workflow as smooth as possible buttons could be added to Apply the new connector pane, Apply and reorganize the front panel, Reorganize the front panel or Cancel the whole operation.
To make sure that we don't lose existing functionality the CTRL + left click shortcut shall keep the swap terminals functionality (a.k.a.: switcheroo).
Removing controls from the connector pane could be done by the right click, or left click for selecting the terminal and then using the Delete button on the keyboard.
Other operations inside the context menu, like the rotate by 90 degrees, add terminal, remove terminal, etc. could be made available via the menu of the window. I personally use these less, but if there is need for them, then we can discuss how they shall be presented on the window.
Since this idea was formulating over a long period of time in my head, but by no means lot of tought put into it, I'm very open to discuss the details. And, by no means the only or best solution to improve the Connector Pane UX.
7 Comments
Christina_R
Active Participant
As a possible source of inspiration, here's the Icon editor from G Web Development Software, which is used to modify both the icon and the connections.
When a terminal is selected, the right-hand pane lets you choose the usage (and more):
When no terminal is selected, the right-hand pane is used to pick the pattern (and more):
Christina Rogers
fefepeto_kb
@Christina_R I appreciate sharing this solution here. I have to admit that I never used NXG, neither at NI, nor since then. It seems quite like an improvement. I'm also not pushing for reinventing the wheel.
All in all, I think it is a nice starting point for a solution on the idea. Might be combined with some of the details I had above, but as I stated in the original post I'm not keen on pushing for those.
BertMcMahan
Trusted Enthusiast
Perhaps you'd find this interesting- NI has open sourced the icon editor: https://github.com/ni/labview-icon-editor
fefepeto_kb
I'd prefer that the built in experience is improved, making changes in the icon editor on our own is a good option though.
joerg.hampel
Active Participant
Just to clarify: The open-sourced NI Icon Editor is "the actual product". Accepted changes will be fed into new releases of LabVIEW.
fefepeto_kb
I rephrase: Having the connector pane where it is now shall be improved unless decision is taken to move it in the icon editor.
My motivation for this would be to avoid having two separate places where the same thing can be achieved.
The current placement of the connector pane makes it easy to access, because it is on the front panel window.
Moving it into the icon editor would require major modifications to the icon editor itself, to allow interaction with the front panel controls while the connector pane is edited.
The other potential problem with the now open source icon editor is, that users can have their own modified version spun off, that they use to replace the shipping version. Adding a functionality like this can easily break compatibility, therefore there must be a good deal of decision making and potential trade-offs for the design.
crossrulz
Knight of NI
Yes, we are trying to tred lightly at the moment with the Icon Editor. It is not the wild west where anybody can put in a change. We have processes of looking at issues, deciding how they should be tackled, getting R&D approval, and then putting the issue open for updates once there is an actual plan. As far as the branching, that can be mostly taken care of in the building of a good API. This is on our list of things we will be trying to do as we refactor a lot of that code.
