Problem: Many native VIs use the Non-reentrant execution reentrancy setting.
Solution: The vast majority of native VIs should use the Preallocated clone reentrancy setting.
- The native VIs that need to use Non-reentrant or Shared clone are few and far between - they should be identified on a case-by-case basis. Their Context Help and/or Detailed Help should explain why they need to be set to Non-reentrant or Shared clone.
The following is a selection of vi.lib VIs that should use Preallocated clone. This selection is meant to serve as a starting point and is not comprehensive.
Notes:
- This idea is related to: The reentrancy of new VIs should be "Preallocated clone" . They both argue in favour of using the Preallocated clone setting more.
- A significant number of native VIs are already configured to use Preallocated clone, which is great.
- There are curious cases where closely related VIs are set to different reentrancy settings. For example, Color to RGB.vi is rightly using Preallocated clone, while RGB to Color.vi is Non-reentrant. Similarly, Trim Whitespace.vi is rightly Preallocated clone, while Normalize End Of Line.vi - which lives next to it on the String palette - is Non-reentrant.
- This suggest that the reentrancy setting of some native VIs was chosen haphazardly. This needs to be rectified.
- The fact that so many native VIs are non-reentrant partly defeats LabVIEW's remarkable ability to create parallel code easily. Loops that are supposed to be parallel and independent are in fact dependent on each other when they use multiple instances of these non-reentrant native VIs. When an application uses multiple instances of these native VIs it is as if there are "hidden semaphores" that are added between the various call locations that call these native VIs. This leads to less performant applications (more CPU cycles, longer execution time, larger EXE compiled code size).
