Hey everyone,
here is my first suggestion.
It is a bit annoying to have two Projects open within a single Labview.exe Process.
Why?
For example if i want to compare my Project Settings of the two Project to sync them, i have to:
- open project settings of Project_1
- memorise the settings
- close project settings of Project_2
- edit setting with memorised informations
- repeat for every settingpage
This works for every dialog, Open, save.....
You have to do this because the SettingsDialog blocks every opend project. Please treat every instance independent of each other.
Regards
Ronny
