Philace
Multi input in case structure
It should be great if it as able to have more than 1 indicator for the condition case.
Today you need to do something like this
But this should be very cool !!
7 Comments
crossrulz
Knight of NI
Please do a search before posting a new idea.
Duplicate: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Multiple-Case-Selectors-along-with-shared-not-se...
Philace
I've already do a search yesterday but between my search and my post someone have the same idea
Norbert_B
Proven Zealot
Also, there are very rare cases where this makes sense. In common cases, you simply put some boolean logic to combine the selector inputs.
Another option next to boolean logic would be "encoding" in integers and use a multi-case case structure with appropriate case IDs.
Norbert
Norbert
Expert: Geometry
Philace
I don't think that its very rare and I already use an integer to run this type of problem but it's a bit restrictive to maintain or reuse and it is also a bit of a pain when there are more than 2 inputs. Moreover, it is less convenient to read, and this kind of functionality can be extended to other types of data.
Philace
AristosQueue (NI)
NI Employee (retired)
Please move this debate to the other thread... there are more comments there relevant to your conversation.
Norbert_B
Proven Zealot
Philace,
i am sorry to strictly contradict.
Either you have a strict separation of combinations (which would be the boolean logic/numeric solution as a SINGLE case structure) or you have case depending differences. So stacking case structures is a must for this.
As an example, we take two boolean criteria A and B. In case we differ between all combinations, we would have:
AB
A!B
!AB
!A!B
Four well defined cases with DIFFERENT code. In this case, the solution is to use a numeric and "encode" the boolean values. It is clean and expandable for additional boolean criteria easily.
If B is only relevant for A, it would be:
AB
A!B
!A
So we got three cases, not four. So in this case, stacking case structures is the proper approach as the difference of B and !B depends on A, but it refers to different code execution depending on B or !B.
So there is NO use case where your feature request is required. In most cases, there is imho a cleaner, more expandible way to address this, which (granted) requires the developer to clearly think about what he wants to do.
I understand the request as is, so please don't mistake me here. But i think that the gain of comfort is not worth the effort to implement it and it could easily create misunderstandings and wrong coding for non-experienced developers.
BTW: How many selectors would you consider appropriate? Two, as your screenshots indicate? Four? Twenty?
Norbert
Norbert
Expert: Geometry
Darren
Proven Zealot
