6 | |
5 | |
3 | |
2 | |
2 |
The default formating for numerics is automatic with 6 significant digits and hide trailing zeros. I'm sure someone thinks this is a great format, however I would like the option to specify default numeric formatting through the ini file. It would be great if this could be applied to the default font for the numeric also.
