cirrusio
Default queue element
Status: Declined
I find this difficult to believe that this has not been suggested before, but a search of the Idea Exchange has come up null.  And maybe there is a reason why this has not been implemented of which someone can enlighten me, but...
Is there anyway we can get a default queue element that is used when a dequeue element times out.  I have found that in several recent projects, I end up with queued state machines that look like this:
21287i411EB0AE3D475742
where I use a select to define a default queue value.  It would reduce some of the code bloat if we had a default value available (that was not necessarily the types default value) such as what you might find in the RT FIFO:
21289i3962134D47D34E02
But, maybe I am missing something?
Matt
13 Comments
cirrusio
Active Participant
Hmmmmm....not at all!  I use some of these state type-def's in different VIs for which the default is not necessarily the same (for a networked application, maybe wait is a default while on a desktop acquire is the default).  This doesn't mean that I have multiple default values in the same VI (that is rather meaningless), but multiple defaults across different applications.  Hence the reason I suggested it.  (And I have seen other applications not developed by myself where they use something similar to what I show in the top image).
Now, this still doesn't seem to answer the question - if this was not of any value, then why was this same technique used for the RT FIFO (where I do use the default value on time out)?  And again, it seems that you may run into some real problems with updating a type def but then forgetting to update the application thus potentially throwing your app into a bad state - not specifying explicitly the state you desire is bad programming practice.  Those are my two cents.  As for the type-def default - I don't fully understand specifying the default for a constant, both the how or why (the how seems to be a real crux).  But, I will let you guys battle that one out...
Cheers, Matt
AristosQueue (NI)
NI Employee (retired)
My argument is that it should not have been.
Darren
Proven Zealot
Status changed to: Declined
