6 | |
5 | |
2 | |
2 | |
2 |
Hallo,
in LabView 2012 it is not possible to remove a once created column in a Tree Control.
As you see in the Picture all Tags were removed, but the Horizontal Scrollbar is still available. I think this is a bug.
Also it would be nice to have a "Delete Clear Column" Function in the right click menu and of course a property-node.
Best Regards
LBekel
