Assume you display more data in an Intensity Graph than supported by the display. Say showing an array of 10000x10000 points on a standard HD display.
Then LabVIEW selects what level to show for each displayed pixel.
And it selects the highest level of all points mapped to a display pixel.
It would be nice to have display options here as a property :
Show maximum ( as now ).
Show average.
Show minimum.
Example : If the scale is 0..100 shown as black..white and the data values are random values of 0 or 100 then the Intensity Graph today will be entirely white. With the suggested display option you could select to show it as either white, gray or black. This is convenient if you look for deviating values in a data set. Today you only see the deviating values that went "positive". With the proposed change you could also look for deviations going "negative". And more ,,
