MECSO
Delete breakpoints from debug window
Status: Declined
The described behavior is a bug, but I need a reproducible case to file it.
Hi all,
when I use breakpoints for debugging, I found that the breakpoints sometimes automatical re-appear after they are deleted from the breakpoint manager. I did some tests and found that they only appear again, when there is no other change in that VI, so the VI is not marked with the * in the title, which indicates unsaved changes. They will also not reappear when the VI is saved manually after the breakpoint is deleted.
So the suggestion is that a VI should also be marked as unsaved after deleting a breakpoint.
Regards, Patrick
_________________________
using LV 2025 Q3
5 Comments
Christina_R
Active Participant
What version of LabVIEW are you using? I cannot reproduce the behavior you describe in LabVIEW 2025 Q3. When I remove a breakpoint in the Debug window, the VI is marked as unsaved.
Christina Rogers
MECSO
I use LabVIEW 2025 Q3 64bit 25.3.2f2
using LV 2025 Q3
Christina_R
Active Participant
If you can provide steps to reproduce the behavior (including a VI), I'll file a Bug. But I'm closing this Idea because the intent is for LabVIEW to mark VIs as as unsaved after deleting a breakpoint, and that's the behavior that I'm seeing.
Christina Rogers
Christina_R
Active Participant
Status changed to: Declined
Christina Rogers
MECSO
Hi Christina,
During writing this post I found the exact way to reproduce it independent from my original project:
The VI will only not be marked as unsaved in case the breakpoint is disabled. Somehow I'm not alowed to uplad a VI or zip file.
So the steps to reproduce it:
  1. Create a VI and set a breakpoint somewhere.
  2. Disable the breakpoint.
  3. Save the VI.
  4. Remove the breakpoint with context menu or in Debug window.
  5. The VI will notmarked as unsaved now.
using LV 2025 Q3
