It would be nice if there were an ability to grey out and not allow selection of an ENUM item if it has already been selected in a previous menu.
For instance, if for "AO Channel 1" you select AO3, when you click the drop down for "AO Channel 2" there should be a way to disable AO3 since it is already in use.
