Problem:
For example I created a type definition with a cluster of four controls. I populated this definition in my program (about 100 VIs).
I am deleting now the second control of my type definition. Of course this new definition is now populating everywhere.
The order is not kept.
Idea:
It should be possible to keep the previous order. I need an extreme long developement to develop and redo everything in my program afterwards.
Screenshots:
Capture 1: Defintion + 3 uses in a VI
Capture 2: Deletion of the second control + the order is not kept: the control 2 is in Position 1 and control 3 in Position 2.
