6 | |
6 | |
3 | |
2 | |
2 |
When your mouse rolls over a structure, a tip appears that tells you what that structure is. This is only useful the first few days that you are learning LabVIEW. From then on, and I've been a LabVIEW developer for 14 years, it is annoying hindrance, often obscuring something that you really want to see. This tip remains up for varying amounts of time depending on the complexity of the block diagram. There should be a way to selectively turn off this particular tip help; others are useful and should remain.
This is something that had subliminally bothered me for a long time. I would unconsciously move the mouse around and click other parts of the bock diagram to get the tip to leave. It was only several years ago that I became aware of this behavior and realized that it doesn't have to be there.
