Its better to disable the functionality of the function keys while a code is running.
One incident i came accross is:
I assigned ESC key for a control and while running the code i wrongly pressed F1 (Which is not assigned to any control) suddenly the Help file started opening and my whole code got hangged. I dont think that some one will need open the help file during code running So its better to disable the original functionality of the function keys just during the code is running.
