It would be nice to have a text\Object option available similar to existing search object/text option but using this option we can search from the VIs even they are not opened/ or are not available in memory.
example: I want to know who are the callers of "abc.vi" in a specific project or in a specific folder. Then I just have to select the "abc.vi" as a object and give the project name or folder name/path and labVIEW will search it in all the VIs of it by opening it one by one 🙂
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
