Like in other languages, I want to disable Test/Debug code in exe mode and have it execute in run mode.
Kind property from the Application Control palette can be used as follows.
http://digital.ni.com/public.nsf/allkb/454C2048938FCD6E8625706E007FEA52
The KB says "When this property node for a VI or executable is used on a real-time system, the property node will always return the value of Embedded LabVIEW."
So this won't work for my RT application. Makes this even more important.
Also I believe the Conditional Disable Structure should have this as a system defined symbol.
Best regards, Pavan
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
