5 | |
5 | |
2 | |
2 | |
2 |
Check out this nice readable diagram:
Whoa there pardner, not so fast. The control reference labeled "Numeric 1" is actually linked to the "Numeric 3" control. And the property node labeled "Numeric 2" is actually linked to the "Numeric 1" control. Etc., etc.
I see no reason to change the labels of Control References and Implicit Property/Invoke Nodes. If you need to document them beyond their label, attach a free label to them. We don't allow changing the labels of subVIs, so the precedent has been set. For the sake of diagram readability, we shouldn't allow changing labels of these objects either.
