Hello everyone,
I have a costumer which had the idea to popup a dialog when compiling code in the application builder when it recognizes that the projects contains more than 10000 gdi objects instead of just crashing. We don't know if this is possible to implement since gdi objects also could created dynamically during execution but I would help if this could be checked when compiling.
Regards
David
