10 | |
3 | |
2 | |
2 | |
2 |
Most of the new LabVIEW users will start programming from the scratch. They really find very hard to understand from where did this particular object (function) came from. So if the location of it is displayed in the context help it will give a better way to easily find that object from the location.
Ex: "Create User Event" can be displayed in context help as below
(or in a shorter form that everybody understands).
Sorry if this idea has been discussed before. Or its not at all needed. For a newbie this will help definitely.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
