13 | |
11 | |
3 | |
3 | |
3 |
Let's uppose I'm sending a sequence of commands to a VISA-controlled instrument (see picture).
While dubugging, I realize I missed a command along the sequence (on following example, I forgot setting output impedance):
As of now, I need to delete the wires between 2nd and 3rd VIs, place the missing VI, then draw the four missing connections.
I'd like Labview to recognize that the I/O pattern of the VI to be inserted is compatible with the existing flow, and to insert it correctly.
Something similar already happens when you place a new VI into the block diagram, and you drag it near a VI with compatible I/O (blinking wires appear).
