Whenever I drag an object's label or caption I can't help expecting the text justification to change too. Is there any use case where this would not be desired?
The current behaviour is particularly inconvenient when I first drag a label, and then later edit the label text:
I feel that "auto-justification on drag" should apply to controls/indicators/constants on the front panel and block diagram.
A search of the idea exchange turned up a mention of this concept here (credit to M*H*), but it seems to have been lost as a sub-idea of a not-so-popular parent idea. I think it deserves a chance of its own!
