6 | |
5 | |
3 | |
3 | |
2 |
It would be useful if QuickDrop supported a way of dropping multiple instances of the same item in one go. It is sometimes desirable to do so. For example, we may want to drop three numeric constants in one go.
The QuickDrop action above would result in three numeric constants being dropped, as seen below.
Selecting an error wire, then executing the sequence: Ctrl+Space >> typing "rn" >> increasing the Number of Items to x3 >> Ctrl+I would result in three property nodes being inserted into the error wire, as seen below.
Notes
