| User | Kudos |
| 11 | |
| 7 | |
| 6 | |
| 5 | |
| 4 |
I just thought of a small thing when I enabled the Dynamic Event Terminals on an event structure for the zillionth time - why don't they just appear automatically when I wire a compatible wire to the structure border? Like this:
Of course once in a while you don't want to wire to the Dynamic Event Terminal, but instead want that wire to tunnel through the structure border, but a dab on the CTRL or ESC key could make the Dynamic Event Terminal "suggestion" disappear.
Cheers,
Steen
