| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 6 | |
| 5 |
Why not be able to easily create BD object references in the same manner as FP objects - assuming the user is using Scripting?
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
