One of the quickest (and easiest to forget) methods to improve performance of your VI is to disable debugging. It requires a trip down the VI properties to get there, however. I propose adding a button on the BD alongside the other debugging buttons to Disable and Enable Debugging.
In LabVIEW 2026 Q1, you can use the Project Environment Settings to enable/disable debugging for all the VIs on a given target, without modifying the VIs.
