| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I suggest that NI should spend a separate Excel-like editor to edit the Tables in LabVIEW.
There are many proposals how to improve the LabVIEW-Table and its editing.
I recommend to stop thinking about improvements and add a separate Excel-like Editor instead.
This Editor could be used to enter, manipulate copy and paste table data. Perhaps more functions like loading data from a file could be added and integrated.
It should be accessible in the editing and running mode.
It should be possible to use it for controls and for constants.
It should be accessible by selecting a corresponding entry in the pull-up context menu (right mouse click).
I hope that this is not another duplicate to this table editing problem
