Right now, we can only edit a few select build specification properties, such as Icon, Name, and DisplayName. I think it would be very useful to be able to edit more of these properties programmatically.
Things I would like to be able to set/read via property nodes:
Build specification name
Target filename
Destination directory
Build specification description
everything under "Version Information"
Other items would be useful as well, but those are the ones I care about the most.
