2 | |
2 | |
2 | |
2 | |
1 |
I have my default label positions set to
Controls and constants, Left-middle
Indicators: right middle
When creating a subVI from the edit menu, control / indicator labels in the SubVI are placed without regard to the rule, so I manually have to move them to the correct place. This is kinda silly, since creating a new control / indicator will place the label correctly.
