Like Select (see this idea), the Array To Cluster and Cluster To Array functions are candidates for a vertical alignement of their input and output.
National Instruments will not be implementing this idea. There is no way to center-align a 2-pixel horizontal wire and a 3-pixel horizontal wire.
