9 | |
3 | |
3 | |
2 | |
2 |
I can't count the number of times I've seen this dialog :
Of course I want to continue, that's why I right-clicked the structure and chose Remove [Structure]! This dialog must be a holdover from pre-Undo days. Do we pop-up a dialog when you select your whole diagram and press <Delete>? What about when you press Ctrl-B? These actions have the potential to remove just as much diagram content as Remove [Structure].
Please get rid of this dialog, and just let us Undo the operation if we need to, just like we do all the other potentially destructive diagram edit operations.
