Zafer.Depe
Embedded Opened Items Window (VIs,Controls,Classes,etc) to Project Explorer window
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
I see there are a lot of IDE change requests already but negative feedbacks don't let fundemantel changes. At least to organise opened windows I have a suggestion. What about to add an embedded window to Project Explorer. As you know, if you have a lot of opened front panels, controls, etc you have to search each one to check which ones necessary and at which one you work on last. If you have 100+ items at Project Window it is not easy to search which ones are opened and which ones you work on. When you open a VI, control,.. it drops down the "Opened Items Window" by the hierarchy among the other opened items and when we mouse over it a small window shows FP+BD same time and when we double click on it (or ctrl+double click for BD) FP opens. Also we can do some other right click operations, close, save, etc...
Idea is expandable in many ways but as it is an opton for anyone doesn't want to use this he/she can shut it down.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
