After configuring a CompactRIO-System with the advisor on http://ohm.ni.com/advisors/crio it would be nice to download an empty LabVIEW-Project containing the CompactRIO-System with its selected modules.
So I can save time selecting the modules manually to start software-development before the hardware is delivered.
Martin
