13 | |
11 | |
3 | |
3 | |
3 |
Hi:
The size of NI Package Library is too large for it includes so many graphic programming information such as front panel.In our view,it is not necessary when the vi is used as function,but not UI.But the 'Remove front panel' Option in the Soure File Settings Config Dialog is disable for user to select.In our point,LabVIEW should allow users to decide each VI wheather to include front panel or not when building a package Library.
Project->build->Packed Library Properties:
