| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
The QD window can be made as "floating type" so that when a shortcut is selected and placed the QD window still remains open. The reason for this,clicking the CTRL+Space is annoying each and every time.
The "close" can be used to close the same once done.
