7 | |
6 | |
2 | |
2 | |
2 |
It's not possible to delete a plot from the graph legend after you extended the legend to a specific number. For example, extend your graph legend to say 10 plots. Later you want to use only 9 plots. You are allowed to prepare your legend for showing only these 9 plots but the 10th plot is still inside the graph. These behavior troubles me especially when using the scroll bar of the legend. In case of this you will always see the 10th Plot, which you don't want to use anymore.
My suggestion: Deleting unused plots should be possible inside the properties menu.
