good day forum
it would be nice if an error locator can be used together with the current indicators. in medium and large applications, where multiple operations are executed in parallel, it could be a challenge just to locate where the error originated from, especially due to modularity, where the error causing function could be from any of the instance within the block diagram. instead of just reporting the function name that encounters the error, perhaps the option to include the nesting structure's information can be beneficial, especially for post deployment investigations, where debug application cannot be used (unavailable/lost source code, etc) and end user can do some self-checking first
several approaches came to me, which mostly revolve around VI scripting during development, that include:
can be a nice feature to have, especially for remote support
