I really like the idea of being able to define error codes and descriptions in an error.txt file. It's very convenient to be able to see all the errors in a single place. However, the location the error.txt file must be stored, to be blunt, stinks. Instead of storing them in user.lib\errors (which creates a useless palette item) how about putting them in user.lib\_errors? It would also be nice if the Error Cluster from Error Code VI had an optional filename input to define which error.txt file to use when looking up the error.
