The one button dialog is a great tool when debugging code. It's very convenient to wire a string to the dialog to probe data when regular debugging techniques are not available. There are times when it would be handy to wire a non-string data type and not have to either convert a number or a boolean to a string. Formatting should be limited (for simplicity) such that data types like arrays and clusters would need to be handled by the user.
