In Ethernet/IP library actualy not suport to use specail service code only get attribute service code 0EH and set attribute 10H, i suggest to add a new Vi to use special service with inputs (Service code , clas,instance , data(array U8) ) with option to use/not use attribute , and output as array U8
See attache image
