Nigel_Hughes
Ethernet/IP toolkit to be able to act as a scanner
Status: New
I really could do with the Ethernet/IP toolkit to act as a scanner rather than just an adaptor. As an adaptor you can write code that will allow a PLC to scan and request data from you, which is fine if you only want a PLC to request data, but I have the requirement to have my Labview app act as the scanner and request data from several different adaptors.
1 Comment
roadrunner250
Yes, would be also very important for me.
And !: It would be nice to have this Information clear communicated before purchasing the Ethernet/IP driver
