6 | |
5 | |
3 | |
3 | |
2 |
I would like an option to prevent projects and VIs that are opened via the EXAMPLE FINDER, from clogging up the RECENT FILES and RECENT PROJECTS menu.
Options should be:
( ) Include example files and projects in RECENT lists (same as now)
( ) Either:
---- Include example files and projects in separate RECENT EXAMPLES lists.
---- Exclude example files and projects altogether.
That would prevent disrupting my history when I go cruising thru the examples after a version update.
