| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 4 |
Hello everybody,
(as suggested I will separate my idea Expand the functionality of Event structures into four seperate ideas to allow giving kudos separately.)
Allow for better handling of the event buffer for fired events of Event structures. I would like to have a feature to list and remove item(s) from the buffer of fired events. Otherwise you have always to write some code to catch events, you d'ont want just to execute or you want to remove, because you just pressed the stop button. This could be realised by new leftside and rightside nodes inside the event structure.
Marc
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
