Jick
Expandable Items window of Enum Properties
Status: New
Many times I have multiple states in my type def enum control. When I edit enum items I would like to see bigger window for better item control. There is lot of empty space on Enum Properties: window but you can't expand Item window at all. Or the window could fill whole applicable space by default.
This would be nice to have option.
BR,
Jick
4 Comments
PhillipBrooks
Active Participant
Off topic:
Could you PLEASE select an avatar image that is not 1357 x 1400 pixels (larger than most desktops)? Google Chrome renders it full size and it uses uneccessary bandwidth/resources regardless of browser...
http://www.zcars.com.au/images/rx8-rotary-engine-40th-anniversary-model1.jpg
http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Forum-Avatars/m-p/1245324#M8146
tst
Knight of NI Knight of NI
Knight of NI
One way of working around this issue is inputting the values directly in the enum control. If you type something in and then press Shift+Enter, LV adds another item to the enum and immediately allows you to edit it. This provides a quick way of adding items.
If you have a lot of items in an array of strings, you can also import them in programmatically. The easiest way is to create a ring, write to its Strings[] property and then replace the ring with an enum, which should maintain the strings.
___________________
Try to take over the world!
Jick
Active Participant
Thanks tst, that's good to know.
Jick
TCPlomp
Trusted Enthusiast
And there is a toolkit at Lava called 'Variant to control' the download for this toolkit includes a 'Strings to Enum' VI.
Ton
My LabVIEW Ideas
