| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
I often click the List Unsaved Changes... link mostly because I need to see the full path of an item and its diffrences in order to determine if I want to keep the new version. I then have to return to the Save Changes Before Closing? dialog box with a mental note of the vi's to keep (more often than not my mental note has a short time to live). The idea I'm suggesting is to be able to mark which vi's to save right in the Explain Changes window. Such as (current vs proposed):
