13 | |
8 | |
3 | |
3 | |
3 |
The request:
The thickness of splitter bars can be resized through the front panel at edit time, but this property is not exposed through property nodes. Why not expose this?
Background:
I use splitter bars all the time for resizable GUIs. They're also cumbersome. Many of the feature improvements I'd love to see have already been captured on this forum. In the mean time, I've got tools for automating what I can -- but I've hit a dead end when it comes to resizing the splitters programmatically. This requested property node doesn't exist and pre-sized splitters can't be copied from template VIs using scripting because the "Move" method throws an error.
