13 | |
7 | |
3 | |
3 | |
3 |
The title says it all.
In 2021 there was excitement about improvements to LVCompare and LVMerge, however there is still no way to compare classes or libraries.
I'm ok with not merging. I know that is a minefield. But at least show me what methods were added, what library or class settings were changed, which VIs moved from private to public and for classes, diff the private data and maybe show changes to the class heirarchy?
