13 | |
8 | |
3 | |
3 | |
3 |
I want to find warnings in an opened VI. For example, a function has moved outside the case or loop structure and is not visible anymore. I call the error list STRG +L and give the show warnings a TRUE. I double click on the specific warning and I get the invisible VI or function highlighted, so I can move it back into the visible area by keys. The problem is, I always have to find the VI in a list of approx. 1000 VIs, which have a warning. It would be great if I would have a search by name function, or I could see the warning/errors of the active VI window.
I have attached an example picture of what I mean (I use a german version)
Cheers
RogerG
