8 | |
3 | |
3 | |
2 | |
2 |
When programming in FPGA, all the timing functions are polymorphic, meaning you have to configure it for either ticks, us or ms. If your not carefull, this can sometimes lead to unwanted error due to simply overlooking a wrong configuration, as in the following example picture:
I propose a simple indicator or different icon to easily see the difference. Something like this, only maybe better looking:
