7 | |
6 | |
2 | |
2 | |
2 |
When developing new VIs f the procedure is usually the following:
1. right-click class or desired location, new VI (static or dynamic dispatch template etc.)
2. Implement functionallity
3. Edit VI icon for easier recognition
4. Save VI
The problem here is that usually the icon allready contains the ideal name for the VI which means I am typing the name of the VI twice, once when editing the the icon and once when saving.
Would it not reduce the development-time by suggesting the name entered in the VI icon editing procedure as the user attempts to save the VI?
I'm currently expanding a large SA with 270 classes and on good days I implement 20-30 VIs and would find it nice if I were not forced to type the name twice.
Interested what experienced LV-users think of this suggestion!?
Available in LabVIEW NXG 1.0. By default, a new GVI's icon will contain text matching the file name of the GVI.
