NIExpert
Fix the LabVIEW Compare Tool
Status: New
The compare tool is fundamentally broken which is somewhat shocking considering that such a tool is essential to any sort of large scale or long term software development.
Attached is a basic LV 2023 example which illustrates some of the many flaws with the tool.  If you compare "old version" and "new version" vi without including cosmetic changes, the tool shows 33 differences, most of which are incorrect.
3 Comments
NIExpert
Another issue is comparing two vi's which use .NET objects.  LabVIEW comparison flags ALL the .NET instances as differences even if both VI's are loading from the same object class from same location
wiebe@CARYA
Knight of NI
The compare got an update in LV24, so maybe base feedback on LV24Q3? I don't know if this in particular changed, but it should be 'better'...
NIExpert
 Sadly the tool is still fundamentally broken in 2025Q3
