I use fixed point values quite a bit, and i do find myself splitting and joining them quite often when I have to roll my own low-level, optimized operations.
The fixed point type is (generally) treated as an arithmetic type (e.g. floating point) rather than a logical type (e.g. integers). The (default) configuration should maintain this behavior.
What I would have found most useful is having Split cut the value in half and return the two properly configured fixed point values. Join would take two adjacent fixed point types and glue them together into one value. This definition would actually make Join equivalent to adding the two values.
Split could take an optional split location which dictates the binary point at which the values are split apart. I suggest defining the value as the location of the lsb (least significant bit) of the high part. In the example, the value would be 0 to get the equivalent behavior. This terminal would require a (immediately computable) constant wired to it since the fixed point output types can't be computed until this value is known.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
